Spencerbozo
Apr 09, 2021Aspirant
Connecting to Owlet
I’m trying to connect the owlet sock to my WiFi. I have reached out to there support and they say “my router is blocking” so it’s my router. In order to connect it to my WiFi I have to join the owlet...
Dsanks08
Aug 13, 2021Aspirant
I'm having this same issue. Has anyone found a resolution?
Aug 13, 2021Guru - Experienced User
You'll need to contact the Mfr for help, information and support for there product.
Make sure the wifi security mode on the modem is supporting of there product. Some devices may not support WPA2/AES or some may require WPA2 and AES so be sure thats enabled on the modem.
Be sure to contact the mfr for help and information regarding this.
Good Luck.
