GuyTeb
Aug 11, 2017Aspirant
Connection continually drops off
It doesn't seem to matter what I do resets etc. my router modem continuously drops connection varies times of the day. Very frustrating!
This website is frustrating too! Pages don't always load!
- DarrenMSr. NETGEAR Moderator
Hello GuyTeb
Are you seeing any timeouts in your modems logs?
DarrenM
- GuyTebAspirant
Hi Darren,
thanks for asking!
I don't see timeouts but I do keep seeing something called Ping of Death. It is coming from Port 0.
i also get these messages:
[DoS attack: TCP- or UDP-based Port Scan] from 8.8.8.8, port 53 1 Wed Aug 16 13:46:46 2017 24.21.236.254:40844 8.8.8.8:53
Any ideas?
- GuyTebAspirant
Also you are right I looked further and found some timeout events like this one:
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:7f:b9:dc:77:c8;CMTS-MAC=00:9e:1e:59:35:5d;CM-QOS=1.1;CM-VER=3.0;
Thanks for for your help!
You may want your ISP to send a tech to check things out.
DarrenM
- GuyTebAspirantThanks yes we have done that a couple of times with same result. So after reading more discussion here I am getting a new splitter and new cables and hope that this works. If not I may look at Motorola as an option. Comcast has checked signal strength throughout the house.
Weird that this is a problem that seems to be associated with Netgear.
