anothernetizen
Jun 12, 2024Aspirant
Connection issues with c6250
My router is having intermittent connection issues. Periodically it'll just cut out and I won't have a connection for 5 minutes or so before it comes back. On the bottom, it's labeled as a Netgear AC...
Jun 12, 2024Guru - Experienced User
Ok power levels are good.
However you have correctables and un-correctables that should be mostly zeros.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
anothernetizen
Thank you! I'll give all that a try. Will report back here if there continues to be any issues.
- FURRYe38Jun 12, 2024Guru - Experienced User
đ
