Dolito
Nov 12, 2019Aspirant
Connectivity? issues with C7000|Nighthawk - AC1900
The issue I'm having is when I try to use my roku in my bedroom with Youtube TV the picture freezes for 20-30 seconds every few seconds and every so often would tell me to check my connection. I swit...
Nov 12, 2019Guru - Experienced User
Are you connecting your roku to the 5ghz?
have you tried changing wifi channels? If you're on the lower 5ghz, try the higher 149+ channels.
Some apps will dynamically change their resolution (like netflix) based on bandwidth available. It might be why its working with some apps and not others.
Are you using mu-mimo?
