Dolito
Nov 12, 2019Aspirant
Connectivity? issues with C7000|Nighthawk - AC1900
The issue I'm having is when I try to use my roku in my bedroom with Youtube TV the picture freezes for 20-30 seconds every few seconds and every so often would tell me to check my connection. I swit...
Dolito
Yes, the roku is connected to the 5ghz.
No I havent changed channels yet, the 5gzh worked well on my phone, so I didnt want to mess with it. Is there a rhyme or reason to the channel numbers or just go through them and see which works best?
Netflix worked flawlessly, the picture was crisp and never studdered or buffered or anything, with YTTV, the picture was decent for the most part, when it was running, but it would freeze for longer intervals when it was actually working for.
Whats Mu-mimo?
Is there a port or something that needs opening?
Nov 12, 2019Guru - Experienced User
Usualy 5ghz is more resilent because it doesn't broadcast as far but if your neighbor is on the same 5ghz channel, it can cause slow downs. I've also read (can't remember where) that some roku's respond more favorably to the 149+ channels.
I think the C7000 supports beamforming but I don't think mu-mimo.
If its a port issues, the YTTV forum would know which one.
- DolitoNov 12, 2019Aspirant
Ok, Ill play with the channels when I get home thanks.
I believe it does support beamforming, what does that do?
