JASSY310
Oct 22, 2016Aspirant
Connectivity to Xbox live Nighthawk X6 8000
I play on the Xbox and my buddy plays on windows 10 (crossplay). We can'talk seem to play anything other than Horde on GOW4. He called his ISP and they couldn't help him because they couldn't connect ...
JASSY310
Oct 24, 2016Aspirant
The thing is, the nighthawk is connected as the modem. Not a modem connected with it. So will it still work going through these steps regardless? Also it is the Xbox live on the pc not the console. Is it different?
DarrenM
Oct 24, 2016Sr. NETGEAR Moderator
Hello Jassy310
Yes you still would want to port forward and you may need to check xbox support site to see if the ports are different for the PC version.
DarrenM
