bileck73
Feb 18, 2024Follower
connexon lose on Netgear router c3700
My router loses network connection several times per day for several minutes at a time. ISP Comcast says that the problem is not with them. I bought a new modem/router (c3700). Comcast is not able t...
Kitsap
Feb 18, 2024Master
bileck73 wrote:My router loses network connection several times per day for several minutes at a time. ISP Comcast says that the problem is not with them. I bought a new modem/router (c3700). Comcast is not able to make it work. What is the problem?
Although it may be new to you, the technical design of the C3700 is very old.
If you can, recommend your return the C3700 to the vendor and purchase a newer design. As a minimum a DOCSIS 3.1 device.
