benderd's avatar
benderd
Considering CM1150V Purchase
  Greetings.  I amconsidering a CM1150V modem to replace my Xfinity-rented Arris TG1682G.  After reading some of the posts here, I am a bit confused and concerned.  I currently have no plans to sign...
  • FURRYe38's avatar
    Well it's something to try out and if it doesn'twork you can send the modem back if you find a good seller with a good refund policy.
    DOCSIS 3.1 is stable currently. However thats mostly kept for 1Gg services. Most speeds under that are still using DOCSIS 3.0
    Good Luck.
