Griffy89
Jan 02, 2021Follower
Considering CM1200 for Gigabit connection (Xfinity) + Google Nest Wifi Router + Points
Hello, I am somewhat new to this space and setting up my first smart home. I recently purchased all new Nest Wifi, Audio, etc. products and I'm trying to decide which router to get (as I don't w...
Jan 02, 2021Guru - Experienced User
The CM1200 is a good modem. What I'm using currently. Though I'm on Sparklight and do not use NEST Wifi. My Orbi AX and Orbi AC are working well behind my CM1200. If you don't seen additional WAN ports, NGs CM1000 is a good modem as well.
Things to check for any cable modem:
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
