chris12
Feb 29, 2020Aspirant
Consistently high error numbers on some channels
I'm consistently getting very high error counts on channel ids 15, 22 and 23. Any idea what the cause may be? see attached screenshot
- Mar 01, 2020
No, i"ve seen it quite frequently where a bad connector/cable only cause interference on a few channels.
Feb 29, 2020Guru - Experienced User
Its usually an issue with either the incoming line from your isp, one of the cables, a splitter, attenuator, amplifier, etc. Anything in the line cause cause issues if they've got corrosion, damage, kinks, moisture.
Easiest way to start?
Move the modem to directly where the coax enters the home and hook it up directly without any splitters, attenuator, amplifiers. This prevents something internal to the home causing the issues. If they're still there, check the cable for kinks/cheap ends. Still having the issue? then contact the ISP for them to check the line. It could be an issue on the coax run from their box or even within the hub itself.
