chris12
Feb 29, 2020Aspirant
Consistently high error numbers on some channels
I'm consistently getting very high error counts on channel ids 15, 22 and 23. Any idea what the cause may be? see attached screenshot
- Mar 01, 2020
No, i"ve seen it quite frequently where a bad connector/cable only cause interference on a few channels.
Feb 29, 2020Guru - Experienced User
BTW, this would be the forum for your device.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
- chris12Mar 01, 2020Aspirant
Thanks. For some reason I would have thought a cable issue would impact all channels equally rather than impacting just these specific channels.
- plemansMar 01, 2020Guru - Experienced User
