alocksley
May 05, 2017Tutor
Continuing C6300 Modem Router Readyshare No USB Drive
this was a thread closed for lack of activity. However, I've had a USB drive connected to the port of my C6300 for a couple of years, and all of a sudden the drive is no longer recognized. The driv...
alocksley
May 18, 2017Tutor
No other answer? By "jump drive" if you mean USB drive well that's what all this was about in the first place. Even a thumb drive doesn't work.
Anyone else seen issues with the firmware upgrade? Even tried factory reset, but then the ISP will sense the downlevel and reflash the firmware.
SUggestions?
waterpass
May 27, 2017Aspirant
I'm experiencing the exact same issue. I got Segete 750GB not recognized but it seems to be ok with a smaler HDDs or thumb drives.
Is there a cure?
- alocksleyJul 14, 2017Tutor
HEY NETGEAR!!!
would you mind replying to this thread? The USB drive is not recognized. THe USB indicator on the front of the modem doesn't even light when I put the drive in. Large or small drives, no difference.
Either admit there's a problem and fix it or come up with a solution. I'm looking for help here, not a sewing circle.
