Darksound
Dec 18, 2023Aspirant
Continuous Blinking Downstream Light on CM1200
I just upgraded my cable package to 500Mps with Cox Cable. DIdn't have any issues before I added the new hardware. Now the downstream lights and continuous blinking after a few hours of resetting the...
Darksound
Darksound
Firmware V2.02.03 which is listed on the Cox website.
- FURRYe38Dec 18, 2023Guru - Experienced User
Need this information:
- DarksoundDec 18, 2023Aspirant
Gotcha, my router also started disconnecting. I updated the firmware and did a factory reset. I will post that if and when the issue resumes again. It did have several uncorrectables in the right columns. Now it's at 0.
Need to know the power levels across all channels.
Also, Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
