tyvay
Sep 13, 2020Follower
Converting N 600 combination router to MODEM ONLY (model c3700v2)
Due to just buying a well reviewed mesh router system, I want to use my C3700 N600 Modem Router as a MODEM ONLY. Netgear site advises against it, except under special circumstances. Why is that? ...
Sep 14, 2020Guru - Experienced User
You can change the combo modem to modem only mode. Review the user manual for this infromation. IF you want to run a different router behind the modem, then this would be recommended. Having two routers on the same line can cause problems.
