JNWillow
Mar 06, 2025Aspirant
Correctables & Uncorrectables high
Downstream Bonded Channels Channel Locked Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 11 Locked QAM 256 11 345000000 Hz 9.5 40.3 2094 2516 From the Cable Diagnosti...
Mar 07, 2025Guru - Experienced User
Correctables should maintain zero or near zero levels. This can be caused buy bad cabling, loose connections.
JNWillow
Mar 08, 2025Aspirant
So, without rebooting, the numbers get bigger (5255 7330). If one column is correctable then what can be done to "correct"?
It sounds like labels A and B would be just as good and provide no information either.
I called Spectrum Technical Support and the clerk had never heard of correctables. What good is that?
I did arrange for a technician to come and check the cable to the house.
I also ordered an attenuator. Is the technician supposed to have one?
I gotta go.
- KitsapMar 08, 2025Master
Web search is your friend!
https://duckduckgo.com/?q=cable+modem+correctables+uncorrectables&t=newext&atb=v167-1&ia=web
