DannyS22
Feb 23, 2023Guide
Costco CAX30 Router
I got an email stating that my CAX30 router might have a problem connecting to the internet. I checked and had my traffic meter already cleared. I'm guessing that with that, I'm good. I have not had ...
- Feb 27, 2023
Correct.
Feb 23, 2023Guru - Experienced User
Then you should be good and I wouldn't worry about it.
- DannyS22Feb 26, 2023Guide
This is going to sound dumb but, I seemed to have lost my 5Mzh Wifi. I've lost it on my Android phone and my AC1200 USB 3.0. I see and can connect to my 5Mzh guest connection, but the regular 5Mzh doesn't show up. I've had absolutely no issues from date of purchase to the last week.
Ideas????
Thanks for the help.
Danny
- plemansFeb 27, 2023Guru - Experienced User
did you try a factory reset?
Or try downgrading the firmware on the router?- DannyS22Feb 27, 2023Guide
I have not. I will do that now. When I first got the router someone here suggested to change the channels. I need to go back and find that reply to double-check my settings.
THANKS for the reply and help.
Danny
