DannyS22
Feb 23, 2023Guide
Costco CAX30 Router
I got an email stating that my CAX30 router might have a problem connecting to the internet. I checked and had my traffic meter already cleared. I'm guessing that with that, I'm good. I have not had ...
- Feb 27, 2023
Correct.
DannyS22
Feb 26, 2023Guide
This is going to sound dumb but, I seemed to have lost my 5Mzh Wifi. I've lost it on my Android phone and my AC1200 USB 3.0. I see and can connect to my 5Mzh guest connection, but the regular 5Mzh doesn't show up. I've had absolutely no issues from date of purchase to the last week.
Ideas????
Thanks for the help.
Danny
Feb 27, 2023Guru - Experienced User
did you try a factory reset?
Or try downgrading the firmware on the router?
- DannyS22Feb 27, 2023Guide
I have not. I will do that now. When I first got the router someone here suggested to change the channels. I need to go back and find that reply to double-check my settings.
THANKS for the reply and help.
Danny
No firmware update available. A couple of things I noted; Smart Connect is ENABLE, Enable Wireless Gateway Radio Fragmentation Length is at max 2346, CTS/RTS Threshold 2347. I don't know if those things matter. I changed the 5.0Ghz channel from 48 to 36. I did a REBOOT from the web access. Now I can't access the router from the web or the app even though I have internet access (as I'm typing this).
I still don't show 5.0Ghz network access, only the guest network on 5Ghz that are available either on my Android or the PC.
I guess my next option is to push the reset on the back of the router and hope for the best.
Thanks for the help
Danny
I did a router reset and now all my wifi networks show up as available. So I see how this works for now,
I REALLY APPRECIATE your help. Thank you
Danny
- FURRYe38Feb 27, 2023Guru - Experienced User
Curious what ISP are you with and what FW is currently loaded on the CAX30?
Danny
I push the reset button on the back of the router. I assume it's a factory reset.
ISP: Xfinity Cable Gigabit Service
Hardware Version 1.01
Firmware Version V2.1.3.10
Cable Firmware Version V1.04.10
Thanks for your help.
Danny
