DannyS22
Feb 23, 2023Guide
Costco CAX30 Router
I got an email stating that my CAX30 router might have a problem connecting to the internet. I checked and had my traffic meter already cleared. I'm guessing that with that, I'm good. I have not had ...
- Feb 27, 2023
Correct.
Feb 27, 2023Guru - Experienced User
did you try a factory reset?
Or try downgrading the firmware on the router?
DannyS22
Feb 27, 2023Guide
I have not. I will do that now. When I first got the router someone here suggested to change the channels. I need to go back and find that reply to double-check my settings.
THANKS for the reply and help.
Danny
