DannyS22
Feb 23, 2023Guide
Costco CAX30 Router
I got an email stating that my CAX30 router might have a problem connecting to the internet. I checked and had my traffic meter already cleared. I'm guessing that with that, I'm good. I have not had ...
- Feb 27, 2023
Correct.
Feb 27, 2023Guru - Experienced User
did you try a factory reset?
Or try downgrading the firmware on the router?
DannyS22
Feb 27, 2023Guide
No firmware update available. A couple of things I noted; Smart Connect is ENABLE, Enable Wireless Gateway Radio Fragmentation Length is at max 2346, CTS/RTS Threshold 2347. I don't know if those things matter. I changed the 5.0Ghz channel from 48 to 36. I did a REBOOT from the web access. Now I can't access the router from the web or the app even though I have internet access (as I'm typing this).
I still don't show 5.0Ghz network access, only the guest network on 5Ghz that are available either on my Android or the PC.
I guess my next option is to push the reset on the back of the router and hope for the best.
Thanks for the help
Danny
