DannyS22
Feb 23, 2023Guide
Costco CAX30 Router
I got an email stating that my CAX30 router might have a problem connecting to the internet. I checked and had my traffic meter already cleared. I'm guessing that with that, I'm good. I have not had ...
- Feb 27, 2023
Correct.
DannyS22
Feb 27, 2023Guide
I push the reset button on the back of the router. I assume it's a factory reset.
ISP: Xfinity Cable Gigabit Service
Hardware Version 1.01
Firmware Version V2.1.3.10
Cable Firmware Version V1.04.10
Thanks for your help.
Danny
MrPerson
Mar 01, 2023Aspirant
Go to this page and download the firemware:
https://kb.netgear.com/000065403/CAX30-Firmware-Version-1-4-11-2
Once you do, use 192.168.1.1 to login to the router, go to Advanced->Administration->Router Updage
upload the .bin file there, and update. Click okay when it tells you it's an older version.
I had this exact issue, it looks like the V2.1.x firmware is having issues and doesn't appear to even be available anymore - it looks like Netgear pulled it do to the bugs. I think if you downgrade, the problems should be solved. I also have the exact same Costco CAX30 unit and my 5G kept going out, this seems to be working so far!
- DannyS22Mar 02, 2023Guide
THANKS for the reply and help. Interesting that improved firmware sometimes isn't. 🙂
I'll will do it and let you know the outcome.
Thanks again
Danny
Ooooooooooooo I think that was a mistake. My 5G speeds are crap. My phone used to have Dload of over 500Mbps and now 150. My PC used to be 480Mbps now 110 to 130Mbps.
I had firmware V2.1.3.10, now V1.4.11.2
Probably no way to go back so I can get the hgih speeds again???????????
Danny
- firetruckMar 04, 2023Aspirant
my CAX30 has exact same issue, 5GHz keeps going out
not 100% positive, but I think I noticed that it goes back on when I log into admin console via 2.4GHz and open Wireless settings
- MrPersonMar 04, 2023Aspirant
I'm not sure why that would be, but downgrading the firmware shouldn't be the cause for that since that's the same firmware that would have been on your router a few months ago.
The reason you can't go back to the 2.1.3.10 firmware is because it was pulled and the reason for that was that it was causing issues, so it's not a mistake to revert to an older firmware. I had issues with intermittent 5G until I rolled back to 1.4.11.2 and have been getting roughly 500Mbps on it with no interruptions ever since. The only other thing that I can suggest is doing a factory reset on the router, or at least try restarting it again. There may also be settings you want to check to see if anything has changed, such as the SSID channel being used. Netgear has an app called NETGEAR WiFi Analytics. If you select the fourth icon from the left on the bottom (it looks like a radiating circle) it will tell you which channels are being used by other networks around you. If you live near many others, like in an apartment) there's a chance that too many other users on the same channel could affect your internet, so you can try a different channel.
- DannyS22Mar 04, 2023Guide
Well my stupid thought process was it was working before and now not so much. BUT, here's what I've done; hard reset, reset my channels as follows, 2.4 11, 5G 48. Powered off and back on and my speeds apparently are back. 630Mbps on my Samsung Android, 560Mbps on my Samsung Tablet and 575-610Mbps on my USB WiFi PC desktop.
Right now as I write this I'm a happy camper again.
Thanks for the reply and help
Danny
- DannyS22Apr 14, 2023GuideI filled out the beta test request and gave not received a link for the firmware. My router is getting worse. I keeping having to reset for my Samdung tablet to work with 1 game
So what's up?????
Danny
