DannyS22
Feb 23, 2023Guide
Costco CAX30 Router
I got an email stating that my CAX30 router might have a problem connecting to the internet. I checked and had my traffic meter already cleared. I'm guessing that with that, I'm good. I have not had ...
- Feb 27, 2023
Correct.
Apr 17, 2023Guru - Experienced User
Next time try doing a factory reset by using the ERASE button on the modems WEB UI page:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
How log did you press the reset button for? 10-15 seconds is minimum press time, then release. All user configurations should be erased. Recommend setting up with a ethernet connected PC and using a web browser at 192.168.1.1
DannyS22
Apr 17, 2023Guide
Thanks for the help. I will try that and see what happens.
I appreciate the help and patience with me in trying to resolve this issue.
Danny
- FURRYe38Apr 17, 2023Guru - Experienced User
Ok, sounds good. Thank you for the patience. NG IS aware of issues on the CAX30. Why we are helping out with some beta testing as this goes along. There working on it to get stuff fixed.
Please post another Event Logs page as well. Don't clear anything, just copy and past the entire log section please. Remove any MAC addresses from the log before posting. Thank you. - DannyS22Apr 19, 2023Guide
I hope this is what you wanted.
Clear Log Refresh
Time
Priority
Description
2023-04-16 17:20:16
Notice (6)
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:42
Notice (6)
Honoring MDD; IP provisioning mode = IPv6
1970-01-01 00:00:34
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:30
Critical (3)
1970-01-01 00:00:24
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:34
Critical (3)
No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:95:6c:94;CMTS-MAC=CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:24
Critical (3)
2023-04-15 09:23:29
Critical (3)
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29
Critical (3)
1970-01-01 00:00:24
Critical (3)
2023-04-15 09:20:51
Critical (3)
1970-01-01 00:00:35
Critical (3)
1970-01-01 00:00:29
Critical (3)
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:02:36
Critical (3)
1970-01-01 00:02:32
Critical (3)
1970-01-01 00:00:31
Critical (3)
- FURRYe38Apr 19, 2023Guru - Experienced User
Ok You have lots of Criticals that need to be looked at and reviewed by the ISP. Those indicate a signal line issue from the ISP up to the modem. All these report the status or condition of the signal up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlThe signal on the modem side needs to be established and made good so we can be sure any FW loaded on the modem will be stable as well.
Thanks for the reply and help. Our house is 9 years old and there are no know splitters or any other connections from the street to the modem. We did have an unusual amount of rain, so there could be an issue at the street and the connection. I supposedly have Xfinity's Gigabit plan with up to1000Mbps download and up to 20Mbps up. I get notices from Xfinity that I need to upgrade my modem "Your current device can't keep up with the latest speeds" but this NightHawk isn't that old and I'm happy with my current speeds. The reason I got the this unit it was on the Xfinity approved list.
I see what I can get accomplished next.
THANKS again.
Danny
p.s. As a side note it seems that it takes some time for program app graphics on both our Android phones to load. My Samsung S20+ speed tests show 650Mbps down and 18Mbps up using Ookla's app. My Win 10 speed test show 560Mbps down and 18Mbps up from their web site.
Have the line checked to be sure.
And of v.12.2 doesn't seem to work after all this, downgrade back to v.11.2 and let's see what we find on the next FW update from NG.
Be aware that some ISP will market or push marketing information to push customers into getting new equipment when they really don't need it. The CAX30 and 80 is fully supporting of a 1Gb ISP line. What I have and both my CAXs work with this tier.
Also XF has supposedly moved there speed tiers to 800Mpbs and 1.2Gb now and has stopped the 1Gb speed tier. This started last year I guess. This seems to effect some areas where the ISP has operations and some haven't moved the 1Gb tier off the list as I know of others that still have it and its working for them. Other users, the upgraded 1.2Gb speed has caused some problems between the ISP and some modems they use as some modems don't have WAN ports that support 1.2Gb speeds, nor do the LAN ports. aswell on most home class routers. So were seeing some issues here and there with these higher speed tiers with 1Gb ported modems. In most cases the user can have the ISP downgrade to the 800Mpbs package and good operation should continue here. NG is aware of the issues that are tied to this.
I show for in the Gateway Status;
Hardware 1.01
Firmware 1.4.11.2
Cable Firmware 1.04.10
I'll see if Xfinity will come check the line.
Danny
- DannyS22Apr 22, 2023Guide
SO since I'm not the smartest person, why would I have great doadload speed and yet my devices other than my PC take so long to load graphics, like images in Twitter or the game I play?
Danny
- FURRYe38Apr 23, 2023Guru - Experienced User
Can be due to the signal quality on the line. Again, suggestion recommended for the ISP to take a look at.
- DannyS22Apr 27, 2023Guide
So the technician found a splitter I didn't know there was. Here's the event log. Should I clear the log at some point?
Danny
Time Priority Description
2023-04-27 13:30:47 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:32 Notice (6) Honoring MDD; IP provisioning mode = IPv6
2023-04-27 13:23:44 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2023-04-27 13:23:40 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
2023-04-27 13:23:32 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
2023-04-27 13:23:30 Critical (3) SYNC Timing Synchronization failure - Failed to receive MAC SYNC frame within time-out period;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
2023-04-27 13:23:19 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:34 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:30 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2023-04-15 09:23:29 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
2023-04-15 09:20:51 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:35 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:02:36 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:02:32 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:31 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
- FURRYe38Apr 28, 2023Guru - Experienced User
Sure.
Does the modem seem to be working better?
- DannyS22Apr 28, 2023Guide
Seems like so far. Our graphics are loading faster, which was one of our problems.
Should I doa refresh or rest on the logs?
THANKS for your help.
Danny
- FURRYe38Apr 29, 2023Guru - Experienced User
Don't have too. Might save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡 - DannyS22Apr 30, 2023Guide
THANKS
Danny
