ScottZ013
Oct 13, 2022Aspirant
Could There Be A Provisioning Issue?
I got a new Netgear C7000v2 for my Optimum Online service. I pay for 200DL/35UL. With this modem/Router connected, I get 27DL/5UL. I did a self-install and everything went well without errors. Multip...
Oct 14, 2022Guru - Experienced User
Did you try having them reprovision it?
Are those speeds hardwired?
ScottZ013
Oct 14, 2022Aspirant
Thank you for the response. Yes, I had them reprovision the modem. As far as the speeds, I am connected directly to the modem via cat 6E cable. Are there any issues with the cable connection or logs? I'm not sure what to look for.
- plemansOct 15, 2022Guru - Experienced User
Your cable connection looks good but the event logs is the one we need.
