NwadMartin5
Oct 03, 2019Follower
Cox Gigablast CM1200
1GB coming out of outlet according to Cox’s test using their modem. CM1200 wired directly from outlet to modem only getting about 300mbps. HELP! Netgear says Cox needs to lock or unlock something. Cox...
XXorg
Nov 01, 2019Aspirant
I have a CM1000 - which is on Cox approved list - same issue.
No matter what we tried, stuck at 300Mps.
Cox say to contact NetGear to upgrade the firmware.
Netgear says end users can't upgrade firmware. Endless loop.
At wit's end.
- FURRYe38Nov 02, 2019Guru - Experienced User
NG developes the FW, however ISPs are responsible to test FW on there system to ensure it works there. They should see this issue and if it's not working for them then the ISP should notiify NG.
XXorg wrote:I have a CM1000 - which is on Cox approved list - same issue.
Netgear says end users can't upgrade firmware. Endless loop.At wit's end.
