Sieyes77
Feb 01, 2020Follower
COX Gigablast wtih CM1000v2
Yesterday I bought a CM1000 and upgraded to COX Gigablast 1GB. As of this morning I am not getting anywhere near 1GB download speeds. I've contacted COX twice and both times they just had me do the s...
Feb 02, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Test with a different wired PC.
