Cox-Me-Nitgear
Dec 11, 2021Aspirant
COX says to call Netgear - Netgear says to call COX
Hi team, Our Cox ISP FSE came to our house and determined that the connectivity problems were caused by our CM1200 modem. He recommended a firmware update. Ok great. But how do we update the f...
Dec 11, 2021Guru - Experienced User
Well typical of a ISP agent trying to pass the buck and not going there job!
ALL Cable ISPs are responcible for updateing FW ON ALL cable modems. There NO user modems that users can udpate, sans CAX series which users can update the router side of this product. The modem side still requires the cable ISP to update the modems FW. No exceptions.
What is the brand and model of the host wifi router connected to the modem?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Cox-Me-Nitgear
[quote]ALL Cable ISPs are responcible for updateing FW ON ALL cable modems. There NO user modems that users can udpate, sans CAX series which users can update the router side of this product. The modem side still requires the cable ISP to update the modems FW. No exceptions.[/quote]
Well, here in Mesa Arizona things are different. Cox ** DOES NOT ** push updates on 3rd party modems.
We've been down the rabbit hole of questioning our router(s) and devices(s), sorry. I trust our Cox FSE who showed us exactly what was going on at the modem. Forget the router. Our Netgear CM1200 could not lock on the downstream signal while his monitoring device had no problem whatsoever. We repeated the test several times, same result.
We own this modem and I think that we should be able to push our own updates, as Cox is telling us to do. So why is Netgear not allowing users to update? [Head scratcher].
So… we went with Cox Panoramic Wifi solution. We should have the hardware in a couple days. We are keeping our CM1200 for now until we get comparative test results with the Cox device.
- KitsapDec 11, 2021Master
Cox-Me-Nitgear wrote:
We own this modem and I think that we should be able to push our own updates, as Cox is telling us to do. So why is Netgear not allowing users to update? [Head scratcher].I learn something every day. In general, cable ISP's do not let the owners/users of third party modems update the firmware. There is no means to update the firmware from within the user interface. I would want to know why the modem you purchased, that was presumably advertised as compatible with Cox, is not working on the Cox system. Also a question I would have is where would you get the firmware update?
- FURRYe38Dec 11, 2021Guru - Experienced User
Yes, there are "Some" ISPs that don't update "user owned" modems. ISP owned yes. This varies from ISP to ISP.
The reason why users are not allowed to update FW is that this has been a DOCSIS policy standard for many years. Please, contact the DOCSIS community developers and post your concerns there. They are in charge of how cable modems operate.
One reason why it came about is that Cables ISPs early on didn't have good testing methods in place for testing new modems and FW out. I'm sure there was some non communication handling as well between modem mfrs and ISPs. Modem mfrs would just hand out FW to the ISPs and thinking that the modem mfr was doing due diligence in testing, ISP would push FW to user owned modems and either bugs caused problems or the push would brick the users modem. Thus incurring costs for the ISP to replaced the user owned modems. So due to this, ISPs are now responsible for testing any new FW that the mfr hands them prior to pushing to ANY modem. However 'some' cables ISPs took the stance of to avoid any kind of modem liability, 'some' cable ISP will NOT update user owned modems period. They will only push to ISP owned modems. Not all cable ISPs take this stance. Apparently Cox does. I know Spectrum is another that seems problematic for users owned modems.
If your modem isn't locking in on channels, there maybe a signal line or cable line problem rather a FW issue. Not everything is fixed by FW.
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.htmlFor ISPs that just won't update user owned modems and users seem to have problems with the modems they buy, we recommend to avoid the hassles and use the ISP owned modem, even if you have to rent it.
So… we went with Cox Panoramic Wifi solution. We should have the hardware in a couple days. We are keeping our CM1200 for now until we get comparative test results with the Cox device.- Cox-Me-NitgearDec 11, 2021Aspirant
FURRYe38 wrote:For ISPs that just won't update user owned modems and users seem to have problems with the modems they buy, we recommend to avoid the hassles and use the ISP owned modem, even if you have to rent it.
Thank you Furry for your post. Yes it absolutely makes sense to question the line from Cox, splitters and cabling. But according to 3 different service techs who came to our house in the past few weeks they all confirmed that the signal at the modem is good.
Here is a copy/paste of our status page... we just had an "outage" as I am typing this reply...
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 951000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels (Partial Service)
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 29 951000000 Hz 2.4 dBmV 44.1 dB 0 0 2 Locked QAM256 5 807000000 Hz 1 dBmV 44.3 dB 14 0 3 Locked QAM256 9 831000000 Hz 1.3 dBmV 44.1 dB 0 0 4 Locked QAM256 10 837000000 Hz 1.3 dBmV 44.2 dB 0 0 5 Locked QAM256 11 843000000 Hz 1.5 dBmV 44.1 dB 0 0 6 Locked QAM256 12 849000000 Hz 1.7 dBmV 44.3 dB 0 0 7 Locked QAM256 14 861000000 Hz 1.5 dBmV 44.1 dB 0 0 8 Locked QAM256 18 885000000 Hz 2 dBmV 44.3 dB 0 0 9 Locked QAM256 19 891000000 Hz 1.9 dBmV 44.2 dB 0 0 10 Locked QAM256 20 897000000 Hz 1.9 dBmV 44.2 dB 0 0 11 Locked QAM256 22 909000000 Hz 2.3 dBmV 44.2 dB 0 0 12 Locked QAM256 23 915000000 Hz 2.3 dBmV 44.1 dB 0 0 13 Locked QAM256 24 921000000 Hz 2.2 dBmV 44.1 dB 0 0 14 Locked QAM256 25 927000000 Hz 2 dBmV 44 dB 0 0 15 Locked QAM256 26 933000000 Hz 2.2 dBmV 44.1 dB 0 0 16 Locked QAM256 27 939000000 Hz 2.3 dBmV 44.1 dB 0 0 17 Locked QAM256 28 945000000 Hz 2.5 dBmV 44.2 dB 0 0 18 Locked QAM256 30 957000000 Hz 2.3 dBmV 44 dB 0 0 19 Locked QAM256 31 963000000 Hz 2.4 dBmV 44.2 dB 0 0 20 Locked QAM256 32 969000000 Hz 2.6 dBmV 44.4 dB 0 0 21 Locked QAM256 37 381000000 Hz 0.1 dBmV 45.1 dB 0 0 22 Locked QAM256 38 387000000 Hz 0.3 dBmV 45.2 dB 0 0 23 Locked QAM256 39 393000000 Hz 0.3 dBmV 45.3 dB 0 0 24 Locked QAM256 40 399000000 Hz 0.2 dBmV 45.2 dB 0 0 25 Locked QAM256 41 405000000 Hz 0.2 dBmV 45.2 dB 0 0 26 Locked QAM256 42 411000000 Hz 0.2 dBmV 45.1 dB 0 0 27 Locked QAM256 43 417000000 Hz 0.2 dBmV 45.2 dB 0 0 28 Locked QAM256 44 423000000 Hz 0.2 dBmV 45.2 dB 0 0 29 Locked QAM256 45 429000000 Hz 0.2 dBmV 45.2 dB 0 0 30 Locked QAM256 46 435000000 Hz 0.1 dBmV 45.1 dB 0 0 31 Locked QAM256 47 441000000 Hz 0 dBmV 45.1 dB 0 0 32 Locked QAM256 48 447000000 Hz 0 dBmV 45.1 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 16900000 Hz 42.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 23500000 Hz 43 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 29900000 Hz 43 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 36300000 Hz 43 dBmV 5 Locked ATDMA 5 5120 Ksym/sec 60000000 Hz 44 dBmV 6 Locked ATDMA 6 5120 Ksym/sec 67000000 Hz 44.5 dBmV 7 Locked ATDMA 7 5120 Ksym/sec 74000000 Hz 45 dBmV 8 Locked ATDMA 8 5120 Ksym/sec 81000000 Hz 45 dBmV Downstream OFDM Channels
Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit PowerEnable Extended Upstream Transmit Power
Current System Time:Sat Dec 11 14:06:15 2021System Up Time:16:10:08
Here is a snippet of my event log:
Time Priority Description Sat Dec 11 14:10:40 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:43 2021 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:21 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:13 2021 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:07 2021 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:05 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:02 2021 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:02:01 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1; Sat Dec 11 14:01:57 2021 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=08:36:c9:a3:b9:e0;CMTS-MAC=00:29:c2:00:57:92;CM-QOS=1.1;CM-VER=3.1;
