DESP
Sep 01, 2019Aspirant
Criminal customer service
The system is telling me my modem is under warranty until 2020 but when I call in, Netgear tells me I have to pay a one-time $50 fee to even start the process. This is wrong. I feel absolutely taken b...
Sep 01, 2019Guru - Experienced User
Maybe a forum moderator and help you.
Are you having a problem with your modem?
What model# modem do you have? C or CM####?
DESP
It’s a cm500v
My internet goes out randomly several times a day. It’s been happening for about a month.
I have done a hard reset of both modem and my router. I have followed the reboot sequence as well.
I have also reset set the modem via the pinhole in the back.
The modem is showing it is connected to the internet but I am getting no internet either from my network or if I plug directly into the modem.
I also have spoken with my provider as to whether or not the internet is up.
Thanks,
Dean
Thanks,
Dean
- FURRYe38Sep 01, 2019Guru - Experienced User
Have you had the ISP check the signal and line quality up to the modem?
Be sure there are no coax line splitters in between the ISP service box and modem.
Be sure your using good quality RG6 coax cabling up to the modem.
Is there a wifi router in between the modem and your test device?
Remoe the router and connect a wired PC to the modem directly to see if problem happens here.
