MJ42
Mar 09, 2023Aspirant
CS7800 & firmware
From a novice, I thought I had been quite diligent when I selected the CS7800 modem/router, it installed fine, is working fine. Overall, very pleased, and I was able to return the rented modem to the...
- Mar 10, 2023
You're stuck. The ISP is required to do so as its part of the provisioning.
But suddenlink/optimium is horrible at doing so and rarely does.
So not much to do.
Its one of the reasons (not the only) that we recommend buying a modem separate from the router so you control the firmware/settings on the router and not an ISP who doesn't care.
Mar 09, 2023Guru - Experienced User
Ok so for any C or CM series modems, ALL FW updates come from the ISP:
There are no end user FW upgrade options for these model modems.
MJ42
Exactly. That's the page Netgear sent me this morning. Thanks for responding!
- plemansMar 10, 2023Guru - Experienced User
So not much to do.
