Sajoe
Oct 05, 2015Follower
CURRENT FIRMWARE
I have a CM400 cable modem that will not connect and I can't get a RMA for. I checked the troubleshooting page and it says that the firmware for my ISP (TWC) should be V1.01.13 but the modem lists V1...
vkdelta
Oct 05, 2015NETGEAR Employee Retired
It should be problem with the FW. Most of time whey dont see the device on their side it would mean:
- The modem is not online yet (Are DS/US/Online LEDs SOLID GREEN?) pls check this one
- Double check the MAC Address you have provided them. At times I have given wrong MAC by mistake. Pls check this again.
can you please share power numbers and Event log. I can try to tell from that what is happening on your modem.
Also, please PM me picture of back(including product label) of your CM400 if possible.
Netgear
