AngusR
May 09, 2016Aspirant
D6400 Power Outage Orange Internet LED
Good afternoon all We had a tempoary power outage this morning and it seems to have caused some major problems with my router. I have completed a full reset of my router which includes unpluging ...
VE6CGX
May 09, 2016Master
Since you plugged in the old router, in the mean time you can play with D6400 with only PC connected. First of all, can you ping the router? If it does what is the TTL value you see? If you try to log in using default address 192.168.1.1 what happens?
AngusR
May 10, 2016Aspirant
Hi, thanks for the reply
I have hooked up the router to my PC and have been able to access it without any issues. The router itself has all the settings loaded and I have done this by using the auto set up and the manual. The issue is around the routers connection to the ISP. The DSL link light is solid green but the internet light is solid orange. I have tried to get the router to manually disconnect and reconnect to the ISP but this has done nothing. Interestingly when I click to connect to the ISP nothing seems to happen, this was not the case with my old Netgear where when I clicked connect, the small box refreshed as if it was establishing the connection.
- VE6CGXMay 10, 2016Master
Then one more thing, did you power cycle the modem? Sounds like router is OK. Just to be sure run this command
to check you NIC-LAN port connection. ping localhost This is loopback test to make sure related components are working
OK.
