riemarie
Aug 17, 2015Aspirant
date is wrong on my N300 C3000
after moving my N300 C3000-100NAS across the room and connecting it to the same cable connection it was connected to directly before moving it the date went to 1972 after this it will not allow more t...
DarrenM
Aug 18, 2015Sr. NETGEAR Moderator
Hello riemarie
When you say genie are you meaning the app or are you talking about in the router login? and could you give me some screen shots of this. hope to hear your feedback
DarrenM
riemarie
Aug 19, 2015Aspirant
- riemarieAug 19, 2015Aspirant
- DarrenMAug 19, 2015Sr. NETGEAR Moderator
Hello riemarie
Have you tried doing a factory reset by holding a paper clip in the hole in the back for 10 sec? wasnt clear when you said reset if thats what you did or just unplug it. Hope to hear your feedback.
DarrenM
yes have done factory reset with paperclip in the back a few times now also have reset the router through mediacom and have left it unplugged over night as per their suggestion...
