riemarie
Aug 17, 2015Aspirant
date is wrong on my N300 C3000
after moving my N300 C3000-100NAS across the room and connecting it to the same cable connection it was connected to directly before moving it the date went to 1972 after this it will not allow more t...
riemarie
Aug 19, 2015Aspirant
riemarie
- DarrenMAug 19, 2015Sr. NETGEAR Moderator
Hello riemarie
Have you tried doing a factory reset by holding a paper clip in the hole in the back for 10 sec? wasnt clear when you said reset if thats what you did or just unplug it. Hope to hear your feedback.
DarrenM
- riemarieAug 19, 2015Aspirant
yes have done factory reset with paperclip in the back a few times now also have reset the router through mediacom and have left it unplugged over night as per their suggestion...
It sounds like the modem isnt syncing up with the ISP to get the correct time when this happens the modem defaults back to 1970 as default. But as for the one device connecting at a time you may want to check to see if it stuck in Modem only mode and switch it to router mode go to Advanced>Administration> Router mode then make sure that's enabled. if this isnt fixing the connection issue we may need to open a ticket for you and investigate further. Let me know if that helps
DarrenM
yes have done factory reset with paperclip in the back a few times now also have reset the router through mediacom and have left it unplugged over night as per their suggestion... it still works but only for one device at a time ie.. i can connect wirelessly with my phone but noone else in the house can or someone else can and then i cannot. direct ethernet works for the laptop but wireless wont connect if thats connected.. the second and so on devices will say cannot obtain ip address... never had this problem in 3 months.
thank you i will try when i get home. sorry that posted twice didnt realize i sent it the first time. i will update once i try
