Nintendians
Sep 17, 2020Aspirant
dead slow internet speed
i'm only getting 1/10th speed of my xfinity 1gbps (1000mbps) speed plan. tried using all cat5e ethernet cable i have even the one that came with it. still same results. just my gaming pc with the mod...
- Sep 28, 2020Never it was my dad cheap wireless router fault.
Sep 18, 2020Guru - Experienced User
What speed do you get directly connected to the modem?
What firmware version are you on?
Did you just update to gig speeds? If so, i'd recommend a factory reset and reinstall. make sure to leave qos, access controls, traffic monitoring, and parental controls all disabled.
- NintendiansSep 18, 2020Aspirant
100mbps down and 35mbps up
V6.01.06
done, but still same speed results.
- plemansSep 18, 2020Guru - Experienced User
do you have a screen snip of your cable connections page and logs from the modem?
here
