Nintendians
Sep 17, 2020Aspirant
dead slow internet speed
i'm only getting 1/10th speed of my xfinity 1gbps (1000mbps) speed plan. tried using all cat5e ethernet cable i have even the one that came with it. still same results. just my gaming pc with the mod...
- Sep 28, 2020Never it was my dad cheap wireless router fault.
Sep 18, 2020Guru - Experienced User
What speed do you get directly connected to the modem?
What firmware version are you on?
Did you just update to gig speeds? If so, i'd recommend a factory reset and reinstall. make sure to leave qos, access controls, traffic monitoring, and parental controls all disabled.
Nintendians
Sep 18, 2020Aspirant
100mbps down and 35mbps up
V6.01.06
done, but still same speed results.
- plemansSep 18, 2020Guru - Experienced User
do you have a screen snip of your cable connections page and logs from the modem?
- NintendiansSep 18, 2020Aspirant
here
and here
