Nintendians
Sep 17, 2020Aspirant
dead slow internet speed
i'm only getting 1/10th speed of my xfinity 1gbps (1000mbps) speed plan. tried using all cat5e ethernet cable i have even the one that came with it. still same results. just my gaming pc with the mod...
- Sep 28, 2020Never it was my dad cheap wireless router fault.
Nintendians
Sep 18, 2020Aspirant
100mbps down and 35mbps up
V6.01.06
done, but still same speed results.
Sep 18, 2020Guru - Experienced User
do you have a screen snip of your cable connections page and logs from the modem?
- NintendiansSep 18, 2020Aspirant
here
and here
- plemansSep 18, 2020Guru - Experienced User
Your power levels look good. A touch high on the upstream but not horrible.
Have you tried having the ISP re-provision the modem? I've had them send the wrong provisioning before.
Or try replacing the cable?
Is your computer capable of gigabit?
