Steve_105
Sep 26, 2019Aspirant
Detaching Antennas on C7500 Nighthawk X4 AC3200
I recently purchased the Nighthawk X 4 AC3200 Model 7500 and then deiced on getting a separate Netgear Modem and Router. I have to send back the Nighthawk X4 AC3200 Model 7500 and was wondering ...
Steve_105
Sep 27, 2019Aspirant
I don't see where it mentions connecting the antennas or detaching them. The router cannot fit in the carton it came in unless the antennas can be separated somehow and I don't see that they can be detached?
myersw
Sep 27, 2019Master
Sure looks like the attennas are attached to the router. Not sure what to tell you since the quick start does not talk about attaching the antennas like expected.
