Steve_105
Sep 26, 2019Aspirant
Detaching Antennas on C7500 Nighthawk X4 AC3200
I recently purchased the Nighthawk X 4 AC3200 Model 7500 and then deiced on getting a separate Netgear Modem and Router. I have to send back the Nighthawk X4 AC3200 Model 7500 and was wondering ...
posdnya
Feb 25, 2020Initiate
I had the same problem. You need to lay down two right antennas to the left and two left antennas to the right. It's a bit tricky, but if you know that it is possible, you will find a solution in a couple minutes.
