csosa
Apr 16, 2016Follower
Devices cannot conect to guest network C6300
Almost all of the devices I try to connect to my c6300 cable modem router show they are connected but only have limited access. The devices unable to connect are andriod tablets, iphones and windows...
- Jul 31, 2016
Thank you for ALL of your assistance. I did the factory reset and it seems all is good. All four networks are working fine (that includes both guest networks). Mahalo!!
TheEther
Apr 17, 2016Guru
Do you have Access Control enabled under ADVANCED > Security > Access Control?
- djfriendJul 26, 2016Tutor
Yes, Access Control is enabled, but still no internet access using guest networks.
- TheEtherJul 26, 2016Guru
Since you have Access Control enabled, you have to add your devices to the access list. Otherwise, they will not be able to access the Internet.
Thanks, but the screen showed that not only was Access Control enabled, six devices were listed. So, I tried selecting all and clicking on allow. After the update I still have no internet access to my guest networks. Any more suggestions?
