csosa's avatar
csosa
Follower
Apr 16, 2016
Devices cannot conect to guest network C6300
Almost all of the devices I try to connect to my c6300 cable modem router show they are connected but only have limited access. The devices unable to connect are  andriod tablets, iphones and windows...
  • djfriend's avatar
    djfriend
    Jul 31, 2016
    Thank you for ALL of your assistance.  I did the factory reset and it seems all is good.  All four networks are working fine (that includes both guest networks).  Mahalo!!
