csosa
Apr 16, 2016Follower
Devices cannot conect to guest network C6300
Almost all of the devices I try to connect to my c6300 cable modem router show they are connected but only have limited access. The devices unable to connect are andriod tablets, iphones and windows...
- Jul 31, 2016
Thank you for ALL of your assistance. I did the factory reset and it seems all is good. All four networks are working fine (that includes both guest networks). Mahalo!!
TheEther
Jul 29, 2016Guru
I agree. I can't think of any other reason why devices on the guest network cannot get an IP address or access the Internet. You want to consider a factory reset.
djfriend
Jul 31, 2016Tutor
- rawise1952Aug 06, 2016Aspirant
Aloha,
I've been trying to find the ACL's I created before the revision update, did you get those back after factory reset?
Mahalo
- TheEtherAug 06, 2016Guru
No, you will lose them after a factory reset.
