Afkinch
Apr 10, 2020Aspirant
Devices losing connection with c6300 repeatedly
Devices lose internet. Restart device and gets reconnected. Constant ping shows sporadic higher return times hundreds ms. Clears up then has a regular spike. We have about 20 devices on. Connect via ...
Afkinch
Apr 13, 2020Aspirant
Equipment: Netgear C6300
Computer: HP Laptop
Connection: Wireless connection
Ethernet: Shows no issues when I connect to it.
Problem: Computer responds terribly slow at intermittent times.
Troubleshooting conducted:
Ran a continuous ping to gateway 192.168.0.1 and received round trips that bounce from 3ms to 300ms sporadically.
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- FURRYe38Apr 13, 2020Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?- AfkinchApr 13, 2020Aspirant
Changed my 2.4 GHhz to channel 9, I show about 30 Access points, but there is only 4 on Channel 9; already set to manual. 5GHz has been changed as well. I have been monitoring the channels and changing when their busy.
This problem has only recently started in the past 3 or 4 weeks. Before that I did not have a problem. Nothing recently has changed on my network. The Netgear C6300 is 3 or 4 years old.
Was looking to see if the Netgear C6300 was at its EOL, but unable to determine that the Netgear website.
- FURRYe38Apr 14, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 9 is not a primary channel to use.
ALso try turning down the power output on the radios from 100% to 75 or 50% to see if this helps any since you have other wifi nieghbors near by. Under Advanced Tab/Advanced Settings/Wireless Settings
