Afkinch
Apr 10, 2020Aspirant
Devices losing connection with c6300 repeatedly
Devices lose internet. Restart device and gets reconnected. Constant ping shows sporadic higher return times hundreds ms. Clears up then has a regular spike. We have about 20 devices on. Connect via ...
Afkinch
Apr 13, 2020Aspirant
Equipment: Netgear C6300
Computer: HP Laptop
Connection: Wireless connection
Ethernet: Shows no issues when I connect to it.
Problem: Computer responds terribly slow at intermittent times.
Troubleshooting conducted:
Ran a continuous ping to gateway 192.168.0.1 and received round trips that bounce from 3ms to 300ms sporadically.
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Apr 13, 2020Guru - Experienced User
- AfkinchApr 13, 2020Aspirant
Changed my 2.4 GHhz to channel 9, I show about 30 Access points, but there is only 4 on Channel 9; already set to manual. 5GHz has been changed as well. I have been monitoring the channels and changing when their busy.
This problem has only recently started in the past 3 or 4 weeks. Before that I did not have a problem. Nothing recently has changed on my network. The Netgear C6300 is 3 or 4 years old.
Was looking to see if the Netgear C6300 was at its EOL, but unable to determine that the Netgear website.
- FURRYe38Apr 14, 2020Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Channel 9 is not a primary channel to use.
ALso try turning down the power output on the radios from 100% to 75 or 50% to see if this helps any since you have other wifi nieghbors near by. Under Advanced Tab/Advanced Settings/Wireless Settings
- AfkinchApr 16, 2020Aspirant
I reduced the power and changed the 2.4GHz settings to 6 and at first I thought the problem was solved. Yesterday was much better...could still see a hit about everhy 30 secs. Thought I would just watch it another day or so, but then everything went bad...here are the info I captured:
HP Laptop
Netgear C6300
Here is the continous ping to my gateway...
Reply from 192.168.0.1: bytes=32 time=483ms TTL=64
Reply from 192.168.0.1: bytes=32 time=532ms TTL=64
Reply from 192.168.0.1: bytes=32 time=777ms TTL=64
Reply from 192.168.0.1: bytes=32 time=505ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1381ms TTL=64
Reply from 192.168.0.1: bytes=32 time=606ms TTL=64
Reply from 192.168.0.1: bytes=32 time=202ms TTL=64
Reply from 192.168.0.1: bytes=32 time=690ms TTL=64
Reply from 192.168.0.1: bytes=32 time=701ms TTL=64
Reply from 192.168.0.1: bytes=32 time=561ms TTL=64
Reply from 192.168.0.1: bytes=32 time=504ms TTL=64
Reply from 192.168.0.1: bytes=32 time=377ms TTL=64
Reply from 192.168.0.1: bytes=32 time=427ms TTL=64
Reply from 192.168.0.1: bytes=32 time=381ms TTL=64
Reply from 192.168.0.1: bytes=32 time=428ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1086ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1076ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1487ms TTL=64
Reply from 192.168.0.1: bytes=32 time=807ms TTL=64
Reply from 192.168.0.1: bytes=32 time=18ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1188ms TTL=64
Reply from 192.168.0.1: bytes=32 time=79ms TTL=64
Reply from 192.168.0.1: bytes=32 time=209ms TTL=64
Reply from 192.168.0.1: bytes=32 time=94ms TTL=64
Reply from 192.168.0.1: bytes=32 time=158ms TTL=64
Reply from 192.168.0.1: bytes=32 time=180ms TTL=64
Reply from 192.168.0.1: bytes=32 time=360ms TTL=64
Reply from 192.168.0.1: bytes=32 time=229ms TTL=64
Reply from 192.168.0.1: bytes=32 time=318ms TTL=64
Reply from 192.168.0.1: bytes=32 time=187ms TTL=64
Reply from 192.168.0.1: bytes=32 time=37ms TTL=64
Reply from 192.168.0.1: bytes=32 time=59ms TTL=64
Reply from 192.168.0.1: bytes=32 time=231ms TTL=64
Reply from 192.168.0.1: bytes=32 time=366ms TTL=64
Reply from 192.168.0.1: bytes=32 time=143ms TTL=64
Reply from 192.168.0.1: bytes=32 time=210ms TTL=64
Reply from 192.168.0.1: bytes=32 time=279ms TTL=64
Reply from 192.168.0.1: bytes=32 time=240ms TTL=64
Reply from 192.168.0.1: bytes=32 time=320ms TTL=64
Reply from 192.168.0.1: bytes=32 time=102ms TTL=64
Reply from 192.168.0.1: bytes=32 time=197ms TTL=64
Reply from 192.168.0.1: bytes=32 time=78ms TTL=64
Reply from 192.168.0.1: bytes=32 time=496ms TTL=64
Reply from 192.168.0.1: bytes=32 time=434ms TTL=64
Reply from 192.168.0.1: bytes=32 time=432ms TTL=64Reply from 192.168.0.1: bytes=32 time=829ms TTL=64
Reply from 192.168.0.1: bytes=32 time=423ms TTL=64
Reply from 192.168.0.1: bytes=32 time=517ms TTL=64
Reply from 192.168.0.1: bytes=32 time=220ms TTL=64
Reply from 192.168.0.1: bytes=32 time=313ms TTL=64
Reply from 192.168.0.1: bytes=32 time=1032ms TTL=64
Reply from 192.168.0.1: bytes=32 time=739ms TTL=64Here are the C6300 Cable Connection
<tabindex=-1>tartup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 507000000 Hz Locked Connectivity State Ok Operational Boot State Ok Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 1 507000000 Hz 0.0 dBmV 40.3 dB 29 0 2 Locked QAM 256 2 513000000 Hz -0.2 dBmV 40.3 dB 0 0 3 Locked QAM 256 3 519000000 Hz -0.2 dBmV 38.9 dB 0 0 4 Locked QAM 256 4 525000000 Hz -0.4 dBmV 40.3 dB 0 0 5 Locked QAM 256 5 531000000 Hz -0.5 dBmV 38.9 dB 0 0 6 Locked QAM 256 6 537000000 Hz -0.5 dBmV 38.9 dB 0 0 7 Locked QAM 256 7 543000000 Hz -0.7 dBmV 38.9 dB 0 0 8 Locked QAM 256 8 549000000 Hz -0.7 dBmV 38.9 dB 0 0 9 Locked QAM 256 9 555000000 Hz -0.7 dBmV 38.9 dB 0 0 10 Locked QAM 256 10 561000000 Hz -0.7 dBmV 38.9 dB 0 0 11 Locked QAM 256 11 567000000 Hz -0.7 dBmV 38.9 dB 0 0 12 Locked QAM 256 12 573000000 Hz -0.5 dBmV 38.6 dB 0 0 13 Locked QAM 256 13 579000000 Hz -0.5 dBmV 38.9 dB 0 0 14 Locked QAM 256 14 585000000 Hz 0.0 dBmV 38.6 dB 0 0 15 Locked QAM 256 15 591000000 Hz -0.2 dBmV 38.6 dB 0 0 16 Locked QAM 256 16 597000000 Hz 0.0 dBmV 38.6 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 17300000 Hz 44.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 23700000 Hz 45.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 30100000 Hz 45.3 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 36500000 Hz 45.8 dBmV Current System Time: Thu Apr 16 08:46:51 2020 System Up Time: 00:17:20
