Dasi05
Mar 26, 2025Aspirant
Devices not connecting to rbs750p satellite
Not sure if I made a mistake when buying this and setting this up. Bought a CBR750 cable modem/router with one RBS750 satellite. Realized that was not good enough for a large single story house and b...
- Apr 02, 2025
Need to downgrade all RBS to FW that is on the CBK750s web page so they are on the V4 version:
Mar 26, 2025Guru - Experienced User
The RBS750P which is really a RBS350 series, isn't compatible with the CBR750 and RBS750.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
I recommend you find another RBS750 actual unit to use if you need more coverage.
What is the size of the home in sq feet?
