Dasi05
Mar 26, 2025Aspirant
Devices not connecting to rbs750p satellite
Not sure if I made a mistake when buying this and setting this up. Bought a CBR750 cable modem/router with one RBS750 satellite. Realized that was not good enough for a large single story house and b...
- Apr 02, 2025
Need to downgrade all RBS to FW that is on the CBK750s web page so they are on the V4 version:
Dasi05
Apr 02, 2025Aspirant
Hi again,
so I did follow your advice and added 2 RBS750 satellites. Still no devices connecting to the 2 new ones (I have set them up and let them sit since Saturday).
I have just turned off the initial satellite from the original set with the router and rebooted the router. I have carried my cell phone to the most Western corner of the house where I have put satellite #3 (which shows as connected via daisy chain to sat #2 with GHz with a good backhaul status on the web app). The router is in the most Eastern corner of the house. The phone cannot find the network 😞 It's been there for a good 5-10 mins, no dice. What might be going on? Should I open a new thread? TIA!
Router
CBR750 running Orbi Firmware Version V4.6.14.4_2.3.12
3 satellites all the same:
RBS750 running V7.2.7.15
Apr 02, 2025Guru - Experienced User
- Dasi05Apr 02, 2025Aspirant
Just did the downgrade and now it works, what a journey! Appreciate all your help 🙂
- FURRYe38Apr 02, 2025Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
