dtd41
Apr 13, 2019Aspirant
DHCP Address reservations ignored?
This is an unmanaged switch connected to a GS105 unmanaged switch. I have two questions: (1) On the link between the GS108 and the host The left light is green, the right not light; (2) Anything to b...
- Apr 13, 2019
This is a short part borrowed fro the GS105(v5) Installation Guide, very similar in the GS108(v4) Installation Guide - only the left LED indicates a 100 Mb/s (Fast Ethernet) link only. On a complete and healthy cable, a Gigabit Ethernet (1000 Mb/s) must be established.
Hard to say what is killing the DHCP process here ...
dtd41
First sentence is wrong should read on the link between the two switches - sorry :(
- schumakuApr 13, 2019Guru - Experienced User
Hard to say what is killing the DHCP process here ...- dtd41Apr 13, 2019Aspirant
Thanks. I did not expect a RTFM response on an unmanaged switch (my bad) thank for the kind and forgiving reply. Given that info the DHCP issue is probably due to network topology. Thank you again
Had not come to a conclusion ref. the DHCP issue, so left it open.
There is no problem with a topology like
Router<-GbE->G105<-FastEthernet(?)->G108<->Computer
Should work like a charm, permitting the cable isn't to bad.
