dtd41
Apr 13, 2019Aspirant
DHCP Address reservations ignored?
This is an unmanaged switch connected to a GS105 unmanaged switch. I have two questions: (1) On the link between the GS108 and the host The left light is green, the right not light; (2) Anything to b...
- Apr 13, 2019
This is a short part borrowed fro the GS105(v5) Installation Guide, very similar in the GS108(v4) Installation Guide - only the left LED indicates a 100 Mb/s (Fast Ethernet) link only. On a complete and healthy cable, a Gigabit Ethernet (1000 Mb/s) must be established.
Hard to say what is killing the DHCP process here ...
schumaku
Apr 13, 2019Guru - Experienced User
dtd41
Thanks. I did not expect a RTFM response on an unmanaged switch (my bad) thank for the kind and forgiving reply. Given that info the DHCP issue is probably due to network topology. Thank you again
- schumakuApr 13, 2019Guru - Experienced User
Had not come to a conclusion ref. the DHCP issue, so left it open.
There is no problem with a topology like
Router<-GbE->G105<-FastEthernet(?)->G108<->Computer
Should work like a charm, permitting the cable isn't to bad.
