abhinavbanerjee
Sep 28, 2021Aspirant
DHCP issue
The systems connected to router cannot connect to intenet using DHCP from router but works fine after assigning manual IP.
Unchecked the option of Use Router as DHCP Server and rebooted. Again checked the same and rebooted but issue remains the same.
What modem/gateway is it connected to?
you also posted in the cable modem forum and not the nighthawk forum for your device.https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
- abhinavbanerjeeAspirant
It is connected to ACT fibernet.
It used to work fine but from past 6 months facing the issue.
Upgraded the firmware also.
what gateway do you have from fibrenet?
What actual firmware version are you on?
