insanesquirle
Sep 20, 2017Initiate
DHCP Not working
My once fine-working cable modem has randomly stopped assigning IPV4 addresses to all of my devices. IPV6 is on auto-assign and works fine. I verified that IPV4 is set up for DHCP, but none of my d...
antinode
Jan 19, 2018Guru
> Re: DHCP Not working
How do you know that the fundamental problem is DHCP, and not, say, a
totally broken connection? As usual, showing actual actions with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations. What observations, exactly,
led you to this "DHCP Not working" conclusion?
Do the LED indicators on a wired connection (both ends) always look
good?
If you have a computer with a suitable static IP address (so that it
doesn't need DHCP from the router), preferably wired, can you always
talk to the router's web site?
Many things can leave a computer/device without a good IP
configuration. A bad DHCP server is only one of them.
> I disabled DHCP, rebooted, enabled it, rebooted again and now it's
> working.
How much of all that necessary? Will a simple reboot do the job?
Depending on how deep you want to dive, it may be possible to probe
the operation of the router at a lower level. There are various
programs out there which may be able to enable a Telnet (command-line)
interface to many Netgear routers. (I use the program which I modified,
http://antinode.info/nte , but others are available). Around here
(D7000, V1.0.1.54_1.0.1), for example, I can see if the DHCP server is
running:
# ps | grep -i dhcp
1152 root 704 S /var/udhcpd_1 /etc/udhcpd.conf1
That doesn't prove that it's working, but if it died, then that would be
detectable and interesting.
Bryansix
Jan 20, 2018Aspirant
The telnet thing is interesting. I'll have to check that out when I have time.
I rebooted the router at least 6 times. I tried both a hard power cycle by taking out the power cable and a soft reboot via the web interface. I had connectivity to the router via ethernet and wifi on my computer and neither were getting a DHCP address. ipconfig / release && ipconfig /renew did nothing. Only once I disabled DHCP, rebooted, enabled it, and rebooted again did it finally start assigning IP addresses again.
One thing to note is that the router seems to have lost its time as some point because some of the logs look like they are from 1970.
- antinodeJan 20, 2018Guru
Hmmm. That sounds like a wholly other problem (can't contact
Netgear's NTP servers?).
If this thing's little brain is sufficiently scrambled, then it may
be time to try the usual panacea: a full reset and (manual)
reconfiguration of the router. Or the super-panacea: reload the
firmware (and then apply the ordinary panacea).
> The telnet thing is interesting. [...]
It might be educational to poke around, and try to see what's
happening before geting brutal. But even knowing that, say, the DHCP
server dies spontaneously may not actually tell you what to do about the
problem.
