Gypsyjon
Jan 12, 2026Aspirant
DIAABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link. I am told must disable AP Isolation, howver that is not an option wh...
Jan 12, 2026Guru - Experienced User
Gypsyjon wrote:I am told must disable AP Isolation, howver that is not an option when I go into the modem software.
The modem is not a router and also has no wifi. You likely have a router, and possibly wifi extenders. Can you give details on that equipment?
