Gypsyjon
Jan 12, 2026Aspirant
DIAABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link. I am told must disable AP Isolation, howver that is not an option wh...
Gypsyjon
I have a Netgear Nighthawk CM3000 and an eero mesh networtk.
It has wifi just fine, 2g and 5g.
AP isolation hopefully will solve my problem
I never had this problem when I was using the Mediacom router but since I switched it seems that I have had problem after problem.
I am a ham radio operator and have lots of stuff that will only use 2g.
- GypsyjonJan 12, 2026Aspirant
I am trying to connect to Shark RF link to access my Shark RF M1ke DMR transceiver which. The Shark RF link is used to control the M1ke. I requires the my computer and the M1ke both be on 2g which is no problem, I can easily switch from 5g to 2g. Lots of my ham stuff only use 2g.
- StephenBJan 12, 2026Guru - Experienced User
Did you install the Eero at the same time as the CM3000?
This sounds like an Eero issue.
The eero was in use prior to the router switch over and seamlessly hooked up to the CM3000 and continues to work fine.
