Gypsyjon
Jan 12, 2026Aspirant
DIAABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link. I am told must disable AP Isolation, howver that is not an option wh...
CrimpOn
Jan 12, 2026Guru - Experienced User
The CM3000 modem has nothing to do with radio use. Not WiFi. Not any sort of radio.
Is it correct to assume that the only thing that changed was replacing a previous cable modem with the CM3000?
i.e. the WiFi router system remains exactly as it was before the change?
and.... this M1ke product was connected to WiFi and working correctly before the change?
- GypsyjonJan 12, 2026Aspirant
Yes it worked just fine.
The m1ke still works with this router but I need to be able to access the Shark RF link webpage to control it, i.e add DMR channels etc/
